Hello Guest it is November 13, 2026, 08:00:06 PM
Author Topic: macro to force oupt  (Read 12287 times)
macro to force oupt
« on: February 10, 2011, 03:41:36 AM »
 hi to everybody  :)
as a macro can be made (example m300.m1s)
what it forces an exit to 1(output #7) and another (example m301.1ms)  what does it to 0?
the commanded signal, has to be also active after the reset
thanks
moreno
« Last Edit: February 10, 2011, 03:47:32 AM by riporeno »
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
Re: macro to force oupt
« Reply #1 on: February 10, 2011, 06:39:51 AM »
Hi moreno
M300.m1s
activateSignal(OUTPUT7)
M301.m1s
deactiveSignal(OUTPUT7)
Add <space>M300 to the initialization string AND tick "use init string on ALL resets" both on the config/general config dialog.
Ian
« Reply #2 on: February 10, 2011, 07:00:14 AM »
ok Ian, thanks for the fast answer
very kind
regards
moreno
« Reply #3 on: February 10, 2011, 07:34:50 AM »
m300 works
m301 goes to error
after some tests I have understood that the exact command is deactivateSignal(OUTPUT7)
thanks
good day
moreno
Offline stirling
  •  2,188 2,188
  • UK
« Reply #4 on: February 10, 2011, 07:47:21 AM »
yes - my typing is quicker than my brain as usual  :)
Ian
« Reply #5 on: February 10, 2011, 07:57:55 AM »
 :D :D
no problem
thanks
moreno
