Mach Discussion => General Mach Discussion => Topic started by: riporeno on February 10, 2011, 04:41:36 AM
hi to everybody :)
as a macro can be made (example m300.m1s)
what it forces an exit to 1(output #7) and another (example m301.1ms) what does it to 0?
the commanded signal, has to be also active after the reset
thanks
moreno
Hi moreno
M300.m1s
activateSignal(OUTPUT7)
M301.m1s
deactiveSignal(OUTPUT7)
Add <space>M300 to the initialization string AND tick "use init string on ALL resets" both on the config/general config dialog.
Ian
ok Ian, thanks for the fast answer
very kind
regards
moreno
m300 works
m301 goes to error
after some tests I have understood that the exact command is deactivateSignal(OUTPUT7)
thanks
good day
moreno
yes - my typing is quicker than my brain as usual :)
Ian
:D :D
no problem
thanks
moreno
