Hello Guest it is November 13, 2026, 03:15:23 PM
Author Topic: Denford Triac ATC - guidance on updating to Mach3(?)  (Read 49295 times)
Offline Sweep
  •  150 150
    • pollz.co.uk
Re: Denford Triac ATC - guidance on updating to Mach3(?)
« Reply #20 on: November 28, 2006, 03:41:08 AM »
Collected the machine yesterday. Got it home and it wouldn't fit through the door  :-[
Not much chance for sub-micron work when I couldn't measure to the nearest inch!
Had to strip off the two rear control panels and even then it was a tight squeeze.
I will have to put it to one side for a few weeks until I finish re-assembling my Smart & Brown lathe, as I don't want too many things in bits at one time, but after that I am sure there will be plenty more challenging questions for all you experts out there in Mach-land.
Thanks ...Richard
p.s. anyone got any spare BT35 toolholders?
« Reply #21 on: November 28, 2006, 07:17:30 AM »
BT35, I have a friend that has a few of the holders, but they are for his mill :(
Best of luck and good to hear you got it in the door !
www.newfangledsolutions.com
www.machsupport.com
