Hello Guest it is November 13, 2026, 08:09:29 PM
Author Topic: Mix and match motors  (Read 11374 times)
Offline dresda
  •  220 220
« on: February 01, 2011, 11:29:56 PM »
Is it possible to use my 3 Dc servo motors with 10 v analogue and DSPMC unit and a stepper motor with it's own drive for the rotary table.
Ray.
  •  9,377 9,377
Re: Mix and match motors
« Reply #1 on: February 02, 2011, 01:24:40 AM »
Hi Ray,
In short yes.
Mach outputs step and direction signals (in an open ended manner) and it really does not care what type of drives/motors you are using.
« Reply #2 on: February 02, 2011, 02:03:22 AM »
I dont think the DSPMC can use Step/Dir drives so I would say no. Rufi will be able to give you a definitive answer though.
  •  9,377 9,377
« Reply #3 on: February 02, 2011, 04:05:16 AM »
Ooops,
Hood is quite right, I was only considering mixing servo drivers and stepper drivers and not operation of Mach under the DSPMC plugin.  :-[
