Hello Guest it is September 30, 2026, 01:38:47 AM
Author Topic: What am I doing wrong?  (Read 14059 times)
« on: November 16, 2006, 06:29:59 AM »
I have set up a tool with diameter 1.6mm.  When I select this tool in lazycam, I expect it to compensate for the diameter of the tool.   So if I am cutting a rectangle inside, I expect the tool path to be half the diameter of my tool (.8mm) away from the edges.  Instead, Lazycam G-Code that moves exactly on the edges of the rectangle.  What am I missing or doing wrong here?
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: What am I doing wrong?
« Reply #1 on: November 16, 2006, 11:36:05 AM »
Hi, jporter
LazyCam is undergoing a re-make, there are some issue's with offset's, Probally better to make a offset layer in your cad to account's for your tool offset's for now, I think.
Are you checking the G41, G42's post options, you need to use Lead-In's ON for them to work/post.
The G41, G42 are Backward's in the Post's for me anyway, view to cut, cut to view, you'll see what I mean.
Hope this Helps, Chip
« Reply #2 on: November 17, 2006, 12:48:46 AM »
Thanks Chip.  That was very helpful.
--Jason
« Reply #3 on: May 01, 2019, 04:19:31 AM »
Hello i'm looking for Cycle Counter For My Mach3 Mill.
I can't understand how to do or put counter of cycle start which i want to display on my screen how many times i started cycle.
Please help me.
Offline reuelt
  •  520 520
« Reply #4 on: May 01, 2019, 04:51:23 AM »
Please help me.
Maybe use MACH3 "BRAINS" for that.
"the gift of God is eternal life through Jesus Christ our Lord"
« Reply #5 on: May 01, 2019, 05:06:22 AM »
Can you please explain how to do that thing ?
i'm new here. I don't know much about how it works and all things.
