Hello
Guest
it is
October 24, 2026, 12:01:14 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Wizard Error
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Wizard Error (Read 14761 times)
slinghit
10
Wizard Error
on:
January 28, 2011, 10:59:38 AM »
I incorrectly entered a bad input into the Spline and Gear Wizard and saved the value. Now I can't reset the error. I keep on getting "Error Rapid Plane <=0******. "E Stop button Pressed" I have since then entered a value larger than zero but the error will not go away. Can you help?
In addition, I have disabled the E-Stop in the Pins and Ports but it keeps on enabling itself. I hit apply after making change. This is a very small machine and the E-Stop is not really needed for the stepper motors.
Thanks for any input.
Jay
Logged
Overloaded
4,923
Re: Wizard Error
Reply #1 on:
January 28, 2011, 11:19:17 AM »
Jay, the estop is permanently enabled as a safety feature, just change the active state and it will then work.
Will look at the wizard later, or someone else will chime in.
Logged
Overloaded
4,923
Re: Wizard Error
Reply #2 on:
January 28, 2011, 11:29:18 AM »
Dont forget to hit enter after changing a DRO, then click Post code to clear the error. If your new value is valid of course.
Logged
stirling
2,188
UK
Re: Wizard Error
Reply #3 on:
January 28, 2011, 11:31:47 AM »
As above - It seems it's just the error ticker isn't correctly reset - just ignore it. Just enter a correct value and post the gcode.
Ian
Logged
Razordance Torch Height Control
slinghit
10
Re: Wizard Error
Reply #4 on:
January 28, 2011, 11:40:25 AM »
I hope I am not asking too dumb of questions.
I assume that changing the active state for the E-Stop is disenabling in Input signals?
I thought I had entered the correct value and posted code but the error still will not go away. I will try again when I get home tonight.
I really appreciate your input.
Thanks Jay
Logged
Overloaded
4,923
Re: Wizard Error
Reply #5 on:
January 28, 2011, 11:56:05 AM »
No, leave it enabled, just change the Active State under the active low column.
Logged
slinghit
10
Re: Wizard Error
Reply #6 on:
January 28, 2011, 11:59:32 AM »
Thanks, Overloaded!!
Logged
Print
Pages:
1
Go Up
« previous
next »
