Hello Guest it is September 22, 2026, 12:37:54 PM
Author Topic: emco compact 6 cnc lathe  (Read 19251 times)
« on: January 28, 2011, 10:42:44 AM »
I have just acquired this cnc lathe with a transformer box (grey box) there are 5 wires from the emcotronic t1 panel but i have no idea where they are supposed to go into the transformer or what power supply into the transformer any ideas
Re: emco compact 6 cnc lathe
« Reply #1 on: January 28, 2011, 11:29:56 AM »
You will have to post a picture of wire and transformer in order to get help.
Jeff
« Reply #2 on: January 31, 2011, 03:26:29 AM »
Hi Jeff here are a few photos
  •  9,373 9,373
« Reply #3 on: January 31, 2011, 03:56:15 AM »
Lez,
As it says on the label that is a 3 phase auto-transformer.
Couple more questions for you,
Do you have a 3 Phase supply available to use with your machine ?
What is the voltage marked on the machine motor ?
What is the voltage of your incoming mains supply ?
« Last Edit: January 31, 2011, 03:59:21 AM by Tweakie.CNC »
« Reply #4 on: January 31, 2011, 04:07:55 AM »
Tweakie
I do have 3 phase supply available
The voltage on the machine motor is 380
and the incoming mains voltage is 440
thanks LEZ
  •  9,373 9,373
« Reply #5 on: January 31, 2011, 05:47:38 AM »
Hi Lez,
The incoming 3 Phase supply connects to the three 440V terminals.
The machine connects to the  three 380V terminals BLACK - RED - BLACK (the GRN/YEL connects to earth on the box and your site earth - the BLU is already connected to the Neutral terminal [240 Volt tapping]).
Test earth bonding of the machine and box etc. before proceeding.
When you start the machine motor, if it runs backwards, just swap the connection of any two wires on the incoming 440V side.
Take care, 440Volt 3 phase is serious stuff - don't let it get you.  ;)
« Reply #6 on: January 31, 2011, 06:00:47 AM »
many thanks tweakie for all your help
« Reply #7 on: February 03, 2011, 05:37:59 AM »
I have now wired the machine up but the monochrome screen keeps rolling and i keep getting an alarm 02 main drive not ready any ideas how to rectify this problem
LEZ
