Hello Guest it is November 22, 2026, 02:27:05 PM
Author Topic: G73 - Pullback setting  (Read 9823 times)
« on: January 25, 2011, 04:12:36 AM »
Can anyone explain why the pullback setting for G73, found under 'Config' / 'Ports and Pins' / 'Mill Options', is not persistent? I want to change this from 0.1mm to 0.25mm and this works while Mach is running but when it is closed down and re-opened, it reverts to 0.1mm. I even tried using the 'Save Settings' on the 'Config' menu but this did not work either.
Is there a good reason why it cannot be persistent?
I searched the forum for an answer and although a few others have noticed the same thing, none has received an answer.
Cheers,
Mike
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: G73 - Pullback setting
« Reply #1 on: January 25, 2011, 08:44:53 AM »
The reason is, wait for it..............  its broken  ;D
It will get fixed but who knows when  :o
Graham
« Reply #2 on: January 25, 2011, 08:52:51 AM »
Thanks Graham, that just about sums it up :) I find it strange that it is not a parameter within the G73 code and has to be set elsewhere.
Mike
  •  2,785 2,785
« Reply #3 on: January 25, 2011, 09:03:35 AM »
Believe me its been mentioned too many time to remember just how many, all I can say is the next major version (V4) is supposed to have all these niggles sorted out.
I can't wait to find out if they are, how about you Hood  ;)
Graham
