Hello Guest it is November 13, 2026, 10:22:14 AM
Author Topic: set distance off home  (Read 18724 times)
« on: January 22, 2006, 05:40:40 PM »
is there any way to set the distance off of home switch?
Re: set distance off home
« Reply #1 on: January 22, 2006, 06:37:50 PM »
look under homing and limits, you will find the settings there.
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: January 22, 2006, 08:30:31 PM »
i tried that maybe i don't understand it , when i set home offset it dosen't move the table .1 off the home switch. it just puts .1 in the dro.  i read the book and wached the video.  how is it susposed to work? in flashcut cut when i set home offset to .1 the machine homes to the switch then moves .1 inch off the switch.  does mach3 operate that way
« Reply #3 on: January 23, 2006, 07:09:15 AM »
I see! You are going to need to change the screen set to make this happen... If you open up screen designer and change the code to this you will get what you are looking for.
DoButton( 24 ) ' ref X
DoButton( 23 ) ' refY
DoButton( 22 ) ' refZ
DoButton( 25 ) ' ref4
Code"G53 G00 X.2 Y.3  Z-.1"
This will tell every axis to move from the home position.
www.machsupport.com
« Reply #4 on: January 16, 2014, 07:25:17 PM »
I'm trying to do something similar and I got the above code to work.   I advance all three axis 0.100 off the home switches by Code"G53 G00 X0.100 Y0.100 Z-0.100".  Now I would like the Machine DRO's to be zeroed.  They are all at 0.1000.  I seem to be able to get them to temporarily zero but then they go back to 0.1000.  Any suggestions?
