Hello
Guest
it is
October 21, 2026, 04:42:53 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Chinese CNCDIY 6040 Machine with Mach 3
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Chinese CNCDIY 6040 Machine with Mach 3 (Read 10496 times)
domenicxx
3
on:
January 17, 2011, 04:41:23 AM »
Hi
am having problems getting the installation with my cnc machine right
this may help someone to tell me what i am doing wrong
Spindle works fine
the X Y Z stepper motors all work
except when i try and manually move using the jog interface the
X- and the X+ all work in the same direction ( to the right )
Z- and the Z+ all work in same direction ( down the table)
Y- and the Y+ dont work at all
I guess i am doing sometime wrong and very basically wrong
can anyone steer me in the right direction
take care
Domenic
Sydney/Australia
Carnoustie, Scotland
Re: Chinese CNCDIY 6040 Machine with Mach 3
Reply #1 on:
January 17, 2011, 04:52:32 AM »
Could you have the dip switches on the drive set for CW/CWW instead of Step/Dir?
Reply #2 on:
January 17, 2011, 04:55:26 AM »
Domenic,
Go to CONFIG>SYSTEM HOT KEYS SET UP and see what key / scan code is assigned to each axis.
In the lower box click the Scan Code button and then press a key board key and it will show you the scan code for that key.
domenicxx
3
Reply #3 on:
January 17, 2011, 04:58:13 AM »
Thank Rich
I will check tomorrow
regards
Domenic
Print
Pages:
1
Go Up
« previous
next »
