Hello Guest it is November 22, 2026, 07:13:20 AM
Author Topic: Chinese CNCDIY 6040 Machine with Mach 3  (Read 10791 times)
« on: January 17, 2011, 04:41:23 AM »
Hi
am having problems getting the installation with my cnc machine right
this may help someone to tell me what i am doing wrong
Spindle works fine
the  X Y Z stepper motors all work
except when i try and manually move using the jog interface the
X- and the X+   all work in the same direction ( to the right )
Z- and the Z+ all work in same direction ( down the table)
Y- and the Y+ dont work at all
I guess i am doing sometime wrong and very basically wrong
can anyone steer me in the right direction
take care
Domenic
Sydney/Australia
Re: Chinese CNCDIY 6040 Machine with Mach 3
« Reply #1 on: January 17, 2011, 04:52:32 AM »
Could you have the dip switches on the drive set for CW/CWW instead of Step/Dir?
« Reply #2 on: January 17, 2011, 04:55:26 AM »
Domenic,
Go to CONFIG>SYSTEM HOT KEYS SET UP and see what key / scan code is assigned to each axis.
In the lower box click the Scan Code button and then press a key board key and it will show you the scan code for that key.
« Reply #3 on: January 17, 2011, 04:58:13 AM »
Thank Rich
I will check tomorrow
regards
Domenic
