Hello Guest it is October 20, 2026, 09:43:40 PM
Author Topic: hex wizard  (Read 29921 times)
hex wizard
« on: January 09, 2011, 09:01:00 AM »
i am doing a job that has basic operations of milling but on 3 of the holes it requires a hex bolt to be flush with the surface. to do this i have to make another program in bobcad at the postions of the holes and let it be done. pain in the rear to put and take the parts just for this. is there somthing i'm missing in wizzards so that operation can be added to the main program? thanks tom
Re: hex wizard
« Reply #1 on: January 09, 2011, 09:40:45 AM »
The wizards allow for individual machining tasks to be done.
I don't use Bobcad, it's a cam program, and  figured that you should not even need to use a wizard to define the machining and generate the code.
Re: hex wizard
« Reply #2 on: January 09, 2011, 09:53:56 AM »
it is so easy to use the wizzards and i'm new to bobcad, so i'll just dive into it some more. need more practice for it is quite a learing curve.
Re: hex wizard
« Reply #3 on: January 09, 2011, 10:38:24 AM »
May as well get used to it since it's never ending..... ;)
Re: hex wizard
« Reply #4 on: January 09, 2011, 11:35:07 AM »
lol you sure got that right.
