Hello Guest it is November 17, 2026, 11:09:03 PM
Author Topic: Can ECP port run G540 with mach3?  (Read 11167 times)
« on: January 02, 2011, 09:32:56 AM »
I have a Dell Inspiron 8200 laptop computer. I went through the optimizing and it passes the driver test. Only question now is will it run a Gecko G540? It does not have a EPP parallel port. It only has Normal, ECP or Bidirectional. Is it absolutely necessary to have a EPP parallel port to run the G540 with Mach3?
Re: Can ECP port run G540 with mach3?
« Reply #1 on: January 02, 2011, 09:45:01 AM »
I think Bi-Directional setting would  work, but its been a long time since I have used the Parallel Port with Mach ::)
