Hello Guest it is November 23, 2026, 07:33:04 PM
Author Topic: File to save for all Mach3 setup  (Read 15299 times)
« on: December 23, 2010, 03:40:50 PM »
I am going to have to reload XP, can someone tell me which file or file's I need to save so I can just move that into the new install of Mach3.
I am hoping there is such a file that has all the pins and backlash , not sure I remember all the things to do for setting up mach3 and it works so great right now.
Thanks for any help
Jim
Re: File to save for all Mach3 setup
« Reply #1 on: December 23, 2010, 03:49:59 PM »
The file is named after the profile you use and has an xml extension, so for example if using the standard mill profile it will be called Mach3Mill.xml if you have a custom named profile then it will have that name.
Other things you may wish to save is the macro folder for the profile you use, it has the macros in it with any custom ones you have made but also it has the fixture offsets and tool table stored in it. Screensets and associated bitmaps may also be required to save if you use non standard screenset and lastly the Brians folder if you have any Brains made.
« Reply #2 on: December 23, 2010, 03:50:56 PM »
Oh and the xml is in the main Mach3 folder, not in the backupxml folder.
« Reply #3 on: December 23, 2010, 07:00:45 PM »
Thank you Hood
Merry xmas and have a safe and good New Year
 Jim
Offline Kai
  •  60 60
« Reply #4 on: December 23, 2010, 07:01:57 PM »
I wasgoing to ask the same question thanks Hood for that.
