Hello Guest it is November 11, 2026, 07:25:19 PM
Author Topic: Rectangle Pocket Wizard cutting off corners in Mach 2!  (Read 16919 times)
Pegasus
« on: November 10, 2006, 10:38:59 AM »
HI everyone,
I am in the process of surfacing my table on my 3DRouters.com 4x8 gantry CNC machine. I went into the Rectangular pocket wizard and gave it the dimensions of the travel limits and to mill down to a depth of .01" (delta of high and low points on the table).
My question is this: It mills along just fine from the inside-out but on two corners it seems to "get ahead of itself" and runs a diagonal from say, the long travel from the X axis to the Y travel when approaching the corners. This only happens on two corners and they are opposite of each other.
It is almost like it doesn't complete the run down the X axis before it wants to run up the Y axis (as an example). Here is a crude ascii art of what I'm talking about:
(Where the "/" are the corners being missed).
I wonder if there is something in setup (ramping?) that is set to fast?
Any and all suggestions would be appreciated
New to Mach 2 in Houston  ::)
« Last Edit: November 10, 2006, 10:40:41 AM by Pegasus »
Re: Rectangle Pocket Wizard cutting off corners in Mach 2!
« Reply #1 on: November 10, 2006, 12:04:41 PM »
Is it just at the last (outside) corners or does i happen on each pass as it moves out?
 Have you checked for backlash or loosness in your y axis?
Pegasus
« Reply #2 on: November 10, 2006, 12:29:24 PM »
Hood,
Thanks for the help. It happens on each pass as it goes out, always on the same corners. I don't have any slop in any of the axis and the other two corners cut just fine.
« Reply #3 on: November 10, 2006, 12:40:09 PM »
What does your code look like for the corners, is it a G2 or G3? It is just that it looks like backlash on one axis and backlash would only affect two of the corners.
  What kind of size is this diagonal?  Have you tried cutting a circle to see if it comes out round or squint?
« Last Edit: November 10, 2006, 12:41:55 PM by Hood »
« Reply #4 on: November 10, 2006, 01:16:24 PM »
Hi Pegasus,
I don't see why It would only do it on 2 corners but with high feed speeds, CV mode and settings can cause this. Does it do it in Exact Stop Mode?
Pegasus
« Reply #5 on: November 10, 2006, 02:18:27 PM »
It happens when transitioning during G1 mode from a long cut down the X axis to an immediate Y cut, i.e;
G1X0Y0
G1X10
G1Y10  (arc happens during this transition)
Looking at it closer I wouldn't call it an actual slant or diagonal, It is more like a smooth arc to join the Y axis intended direction. X never fully gets to G1X10 before it begins the curve to join the Y axis.
Thanks again for your help
« Reply #6 on: November 10, 2006, 03:12:40 PM »
Have you tried it in exact stop mode. Allso, g 61 is Exact Stop And g 64 is CV.
« Last Edit: November 10, 2006, 03:15:56 PM by Chaoticone »
Pegasus
« Reply #7 on: November 10, 2006, 03:39:03 PM »
Let me give that a shot and see what happens.
Thanks!
