Hello Guest it is November 22, 2026, 06:45:17 AM
Author Topic: Need help! Problem with continuing a paused session  (Read 8288 times)
« on: December 14, 2010, 05:45:29 PM »
Helo
I've just recently started using Mach3 software with my cnc machine so this may be a very simple thing  but i am lost at the moment :(
When i stop the machine during a session i write down the current g-code line so i can start from there tomorrow. After closing the program and turning it on again,i load the g-code and input the line form yesterday. I send the machine to my pre-set zeros, and here's the problem, they do not mach the ones form yesterday! Sometimes they are off by 1cm some times nowhere near it!
Re: Need help! Problem with continuing a paused session
« Reply #1 on: December 14, 2010, 06:13:02 PM »
Do you have home switches? If not then you really need to have a fixed point that you can reference to.
