Hello Guest it is October 22, 2026, 10:49:55 PM
Author Topic: Tangential control  (Read 16888 times)
Tangential control
« on: November 08, 2006, 07:39:18 PM »
Does the Tangential control work in G2/G3 in the latest versions ? just curious.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Tangential control
« Reply #1 on: November 09, 2006, 01:21:26 AM »
What would you use it for? just curious.
Graham.
« Reply #2 on: November 09, 2006, 01:44:11 AM »
It was related to the question Gridley51 asked a while back for a plasma.
« Reply #3 on: November 09, 2006, 01:03:39 PM »
Should work... I can make a post for Lcam that will output the moves for the A axis as well :)
www.newfangledsolutions.com
www.machsupport.com
« Reply #4 on: November 09, 2006, 01:36:52 PM »
Thanks Brian, that would be good. Will let Mark (Gridley51) know.
Offline DAlgie
  •  314 314
    • Algie Composite Aircraft
« Reply #5 on: November 09, 2006, 10:18:54 PM »
So, if I read that correctly, tangential control will cut arcs, and not lift and cut them as small straight lines?
« Reply #6 on: November 10, 2006, 06:40:51 AM »
Robin,
thanks for thinking/asking about this.The manual clearly states "curves must be programmed as a series of G01 moves".This is inconvenient but will probably work for what I want to do.I`m a long way away from that stage anyway.
Mark.
« Reply #7 on: November 10, 2006, 10:51:02 AM »
No problem Mark, but the manual also states that" Note: in the current version this feature does not work with arcs (G2/G3 MOVES)"
 As this manual was written way back in April 2005  and since that time Mach has advanced at a remarkable pace, I was thinking it may now be implemented for arcs.
 Maybe Art or Brian can clear this up?
« Reply #8 on: November 10, 2006, 05:20:41 PM »
Art fixed it some time ago (I think) It is a tool that I never seem to use :( I think that I need to get somthing that needs it ;)
www.machsupport.com
