Hello Guest it is October 20, 2026, 07:42:04 PM
Author Topic: help to set A axiz for tangencial cut  (Read 10660 times)
« on: December 10, 2010, 12:41:43 PM »
Hi
Can anyone help me to set the A axis for tangential cut? What I did was activate the A axis on the motor outputs and under general configuration checked A-axis is angular. Then under settings when I activate tangential control I get the square next to it yellow and blinking. The motor does not make any movement.
What am I doing wrong? Please help
Sacramento
Re: help to set A axiz for tangencial cut
« Reply #1 on: December 10, 2010, 01:18:36 PM »
Please post your .XML for the machine profile you are using.
Might be a clue there.
« Reply #2 on: December 11, 2010, 10:39:31 AM »
Enclosed the XLM file for the machine. It was the one made by default when Mach 3 was installed, with some corrections for motor pins.
will appreciate your help.
Sacramento
« Reply #3 on: December 11, 2010, 02:44:07 PM »
Your xml seems to run OK here, just changed your A tuning to speed it up a bit.
Are your axis dro's moving as they should ? just not the motor ?
   If so, double check your wiring. The configuration looks OK.
Also, Tangential was a bit buggy. Not sure if it was fixed completely.
Do a search or two, some good pointers there.
The Radius Correct led was lit too. No need for a correction for tangential, that's for rotary axis work.
If you don't succeed, post back.
Regards
« Reply #4 on: December 14, 2010, 02:11:25 PM »
Thank you very much for your help. Problem is solved now and working perfectly. One of the problems was related with the low speed of A axis. It seems this axis must work at quite high speed.
regards
Sacramento
