Hello Guest it is October 21, 2026, 10:08:43 AM
Author Topic: 4th Axis Help  (Read 9882 times)
4th Axis Help
« on: December 09, 2010, 04:55:46 AM »
I read in a post that 4th rotary axis must be assigned A-axis
I’m using duel ball screws and my A is slaved to my X.
 do I need to change the A to B or can I assign the 4th axis B
Thanks Rusty
Re: 4th Axis Help
« Reply #1 on: December 09, 2010, 06:15:11 AM »
If wanting to view the rotational axis in the toolpath window then I think you will need to swap them about. If not then I dont think it will matter.
Having said that I have never messed with a 4th axis so maybe some of the others who have will chime in with better info.
  •  9,374 9,374
Re: 4th Axis Help
« Reply #2 on: December 09, 2010, 06:37:34 AM »
Rusty,
I agree with Hood, swap your axis so that your rotary becomes Axis A (4). This way you can easily zero the rotary and check it's position or view the program limits etc.
Re: 4th Axis Help
« Reply #3 on: December 09, 2010, 08:24:12 PM »
I did what Tweakie said because when posting for the rotary axis, post will output A axis as rotational move and don't want to mess with
Mastercam post processor to modify it.
Jeff
