Hello Guest it is October 21, 2026, 05:25:34 AM
Author Topic: How to input the setover for the routing tool  (Read 10150 times)
technicrdd
« on: November 07, 2006, 01:26:41 PM »
Am having trouble getting the setover of a .250 ball end cutter setover (0.125").  I want the setover to be around 0.050". Can not tell where or the settings or offsets are to be used.  Can I do this in Mach2 or must I go back to the BobCad program to do the reset to a smaller setover, Help anyone!
« Last Edit: November 07, 2006, 03:32:43 PM by technicrdd »
Offline chad
  •  361 361
  • When the going gets weird, the weird turn pro.
Re: How to input the setover for the routing tool
« Reply #1 on: November 07, 2006, 03:37:20 PM »
That is a setting some ware in BobCam. I would also suggest that you update to the latest version of mach 3.  Mach 2 isn't supported any more and most people are using 3.
Chad
« Reply #2 on: November 08, 2006, 05:59:21 AM »
You will need to set the stepover in BobCad... I can't help you do that as i don't run it :(
www.newfangledsolutions.com
www.machsupport.com
