Hello Guest it is November 13, 2026, 10:03:27 PM
Author Topic: Beta Testers  (Read 13283 times)
Offline GaryB
  •  108 108
Beta Testers
« on: December 05, 2010, 07:41:00 PM »
Looking for beta testers for a new rotary post processor output file from ArtCam to Mach3 for the ArtCam 2011 release
If you use Mach3 and ArtCam Pro with a 4th axis rotary and are willing to beta test the post p then please send an email to support@beckwithdecor.com with beta test in the subject line.
Let me know which axis you're wrapping on either X2A or Y2A and unit of measurement.
If there's outputs you would like included then add them to your email.
thanks
Gary
Beckwith Decor Products
ArtCam Trainer
Onsrud & Custom CNC tooling Distributor
Wichita/Derby Kansas
http://www.beckwithdecor.com
Re: Beta Testers
« Reply #1 on: December 07, 2010, 12:18:35 PM »
Hi
If you want to test also this...
This are in mm.
Andrea
« Last Edit: December 07, 2010, 12:22:33 PM by robotmar »
Offline GaryB
  •  108 108
Re: Beta Testers
« Reply #2 on: December 10, 2010, 08:33:36 AM »
Thanks Andrea
We have done the updated posts but to include them into the Artcam 2011 software release which is in beta right now then we need to have them tested by a number of rotary users to confirm the operational revisions.
Once checked Delcam will verify their operational before adding to the software release.
This method reduces the number of hacked post p's we get sent to us for correction that are currently floating around the net
Gary
ArtCam Trainer
Re: Beta Testers
« Reply #3 on: December 11, 2010, 08:23:17 AM »
Gary, send a message to Jason "Zealouse" Blake, he is a foaming at the mouth Art Cam user......
scott
Offline GaryB
  •  108 108
Re: Beta Testers
« Reply #4 on: December 11, 2010, 08:29:13 AM »
Thanks Scott
will do
Gary
ArtCam Trainer
Re: Beta Testers
« Reply #5 on: February 11, 2011, 06:51:50 AM »
Gary i just got a new cnc 4x 8  mill running and am using mach 3 as driver software, i am used to modlemaster type mills so this is all new i am a beta tester for 2011 artcam and i just saw your post how are they working? will they both  3xs and 4axis rotary will be included i would like to have tested for you my mill rotary is not complete yet but should be in the next week or two, i am yet to try a post pross from artcam yet i ave no tool changer either. the mill is just simple set up so any one could run . i am just not up on witch mach3 posts to use from art cam yet.
