Mach Discussion => General Mach Discussion => Topic started by: GaryB on December 05, 2010, 08:41:00 PM
Looking for beta testers for a new rotary post processor output file from ArtCam to Mach3 for the ArtCam 2011 release
If you use Mach3 and ArtCam Pro with a 4th axis rotary and are willing to beta test the post p then please send an email to support@beckwithdecor.com with beta test in the subject line.
Let me know which axis you're wrapping on either X2A or Y2A and unit of measurement.
If there's outputs you would like included then add them to your email.
thanks
Gary
Hi
If you want to test also this...
This are in mm.
Andrea
Thanks Andrea
We have done the updated posts but to include them into the Artcam 2011 software release which is in beta right now then we need to have them tested by a number of rotary users to confirm the operational revisions.
Once checked Delcam will verify their operational before adding to the software release.
This method reduces the number of hacked post p's we get sent to us for correction that are currently floating around the net
Gary
Gary, send a message to Jason "Zealouse" Blake, he is a foaming at the mouth Art Cam user......
scott
Thanks Scott
will do
Gary
Gary i just got a new cnc 4x 8 mill running and am using mach 3 as driver software, i am used to modlemaster type mills so this is all new i am a beta tester for 2011 artcam and i just saw your post how are they working? will they both 3xs and 4axis rotary will be included i would like to have tested for you my mill rotary is not complete yet but should be in the next week or two, i am yet to try a post pross from artcam yet i ave no tool changer either. the mill is just simple set up so any one could run . i am just not up on witch mach3 posts to use from art cam yet.
