Hello Guest it is October 21, 2026, 04:42:59 AM
Author Topic: Using offsets for a lathe  (Read 8047 times)
« on: December 05, 2010, 03:18:07 PM »
Hello
I am using Mach3Turn for a lathe attachment that I built.
I would like to know if Mach3 can do this:
Call a tool with T command
Move the tool to a start position that I set with the tool offsets
Start machining from that point
Return to machine home position or go to another tool
Thanks for any help
Re: Using offsets for a lathe
« Reply #1 on: December 05, 2010, 05:04:11 PM »
Have a look at Appendix F anf G in the LazyTurn Manual which can be found in Members Docs.
It talks and walks you thru the steps to do what you want.
