Hello Guest it is October 20, 2026, 08:33:48 PM
Author Topic: lathe z direction  (Read 8378 times)
lathe z direction
« on: November 26, 2010, 02:31:42 PM »
I am helping a friend set up his lathe but i cannot get the z axis to run in the correct direction. AKA DRO Z+ traveling left to right away from the spindle when the spindle is on your left side.
So far i have tried.
changing the direction pin in Ports and Pin - this corrects it but the arrow keys work the wrong way.
i have also tried to change the Home/Limits reverse setting and combinations of the two.
All has the affect of having the DRO count the wrong way or having the jog go the wrong way.
I have also tried to reverse the motor by switching 2 of the stepper motor wire but this did not seam to have an affect.
is there a method of just changing the key configuration as everything else works fine. I did not build this machine and is a denford mach 3 conversion. i have built two machine and never been stuck like this, and spending excess time in a garage an 2deg C with no progress is not conducive to a clear train of thought.
Matt
Re: lathe z direction
« Reply #1 on: November 26, 2010, 03:52:22 PM »
Config then System HotKeys, just click on the Z--  and press the key you want then on the Z++ and the key you want.
