Mach Discussion => General Mach Discussion => Topic started by: fragger6662000 on November 26, 2010, 03:31:42 PM
I am helping a friend set up his lathe but i cannot get the z axis to run in the correct direction. AKA DRO Z+ traveling left to right away from the spindle when the spindle is on your left side.
So far i have tried.
changing the direction pin in Ports and Pin - this corrects it but the arrow keys work the wrong way.
i have also tried to change the Home/Limits reverse setting and combinations of the two.
All has the affect of having the DRO count the wrong way or having the jog go the wrong way.
I have also tried to reverse the motor by switching 2 of the stepper motor wire but this did not seam to have an affect.
is there a method of just changing the key configuration as everything else works fine. I did not build this machine and is a denford mach 3 conversion. i have built two machine and never been stuck like this, and spending excess time in a garage an 2deg C with no progress is not conducive to a clear train of thought.
Matt
Config then System HotKeys, just click on the Z-- and press the key you want then on the Z++ and the key you want.
