Hello Guest it is October 21, 2026, 03:27:57 AM
Author Topic: 0.8Kw water spindle running with 2.2Kw VFD  (Read 11407 times)
« on: November 26, 2010, 02:10:27 PM »
Is there any problem running a 0.8Kw water cooled spindle with a 2.2Kw VFD.
Just ordered a 0.8Kw water cooled spindle and I have a spare 2.2Kw VFD both bought from love-happyshopping on Ebay.
I have put a picture of the VFD in case.
Thanks for your time, Jeff
Re: 0.8Kw water spindle running with 2.2Kw VFD
« Reply #1 on: November 26, 2010, 03:54:55 PM »
Usually, this is not a problem. There should be parameters in the VFD that you match up to the motor. It's pretty common to get a higher rated VFD to accommodate a motor upgrade in the future. I do not know anything about the Huanyang stuff.
« Reply #2 on: November 26, 2010, 04:07:59 PM »
Hi, that's what I tough.
I think that 142 is the parameter to be set at 5 to 6 amp for a 0.8 KW motor.
Thanks a lot, Jeff
« Reply #3 on: November 27, 2010, 10:56:26 AM »
I've also done it the other way round -
3kw inverter driving a 5kw motor - it just llimits the max grunt out I can get out of the motor.
(Siemens inverter)
ATB
Derek
You can "chop it off" but can't "chop it on"
