Mach Discussion => General Mach Discussion => Topic started by: ostie01 on November 26, 2010, 03:10:27 PM
Is there any problem running a 0.8Kw water cooled spindle with a 2.2Kw VFD.
Just ordered a 0.8Kw water cooled spindle and I have a spare 2.2Kw VFD both bought from love-happyshopping on Ebay.
I have put a picture of the VFD in case.
Thanks for your time, Jeff
Usually, this is not a problem. There should be parameters in the VFD that you match up to the motor. It's pretty common to get a higher rated VFD to accommodate a motor upgrade in the future. I do not know anything about the Huanyang stuff.
Hi, that's what I tough.
I think that 142 is the parameter to be set at 5 to 6 amp for a 0.8 KW motor.
Thanks a lot, Jeff
I've also done it the other way round -
3kw inverter driving a 5kw motor - it just llimits the max grunt out I can get out of the motor.
(Siemens inverter)
ATB
Derek
