Hello Guest it is October 23, 2026, 12:50:05 AM
Author Topic: Trying to import JPG  (Read 18545 times)
Offline Jim
  •  16 16
« on: November 05, 2006, 11:12:44 AM »
I have Mach3 installed on a PC with 2GB of RAM running XP Pro. I have been trying to import some relatively small jpgs to attempt engraving.  I have resized the jpgs down to 2" X 1.333" at a 72 dpi size.  I used dot diffusion and have depths running between .001 and .006 with a 60 degree engraving bit. After 10 minutes or so, I get a Mach3 not responding message. Has anybody had any success in importing jpgs? Suggested settings?
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Trying to import JPG
« Reply #1 on: November 05, 2006, 11:24:13 AM »
Hi, Jim
What version are you using, Mach3R2.0.008 has LazyCam it, imports Jpgs I think, haven't used it much.
Hope this Helps, Chip
Offline Jim
  •  16 16
« Reply #2 on: November 05, 2006, 03:58:39 PM »
Actually, your reply provided no help whatsoever. During the conversion process is where it dies.
« Reply #3 on: November 05, 2006, 04:04:38 PM »
Are you using the old Import function or are you using LazyCAM?
Offline Chip
  •  2,055 2,055
« Reply #4 on: November 05, 2006, 04:16:56 PM »
Hi Jim
Actually, your reply provided no help whatsoever, for us to Help, Mach3 about 50 versions.
Thank's Chip
Offline Jim
  •  16 16
« Reply #5 on: November 05, 2006, 04:29:11 PM »
I'm using Mach3 that I bought about 2 months ago. The "about" dropdown indicats a 1.********* engine version #. The Mach3 doesn't seem to report whar version or build level.  I'm going to the >file>Import HPGL/BMP/JPG path, where a Mach1Filter dialog box pops up and asks me to "Select type of Import"  HPGL or JPG/BMP  Portions of thsi product yada yada
Where is
Lazy Cam???
Offline Chip
  •  2,055 2,055
« Reply #6 on: November 05, 2006, 04:59:25 PM »
Hi, Jim
Mach3R2.0.008 has LazyCam, it's also a stand alone Gcode generater, I think you can download it separately now, it's in the download section above, It has it's own Icon..
To see what ver. of Mach your using, Help- About- ver #
Give it a try, put it in your Mach3 folder.
« Last Edit: November 05, 2006, 06:15:42 PM by afn09556 »
Offline Jim
  •  16 16
« Reply #7 on: November 05, 2006, 05:40:38 PM »
Mmmmmm,  No LazyCam under my file menu, no "To see what ver. of Mach your using, Help- About- ver #" either. Only Mach Engine display is Version R1.84.001 and my name in the license box.  Maybe I need to download a more current version. 50 versions is a little over the top.
Offline Chip
  •  2,055 2,055
« Reply #8 on: November 05, 2006, 06:23:43 PM »
Hi, Jim
Sorry, under downloads above, you have Mach3184.001, download ver Mach3R2.0.008 above.
Thanks chip
