Hello Guest it is October 24, 2026, 02:51:27 PM
Author Topic: Enter table size?  (Read 10476 times)
Enter table size?
« on: November 21, 2010, 04:19:40 PM »
I'm still setting things up and am a newbie as well...I'm trying to gt everything set, home, soft limits, etc...
Where do I set up my table size so I can see it in the display mode?
Paul
Re: Enter table size?
« Reply #1 on: November 21, 2010, 04:27:56 PM »
That is controlled by your soft limits settings. You may have to press the Display button to toggle it to table view and possibly have to Regen the toolpath.
« Reply #2 on: November 22, 2010, 05:56:01 AM »
OK, thanks, but is the travel vs actual table size a different setting? If so which is which? Sorry to be so ignorant...
« Reply #3 on: November 22, 2010, 06:19:30 AM »
Travel is the same as table size in the respect that it is the area you have for cutting. For example a knee mill may have a longer length than the X axis can travel  and table is narrower than the Y axis travel but the actual distance each axis travels determines the cutting area.
So really instead of saying Table view it may be better to say work area.
