Hello Guest it is November 22, 2026, 02:27:21 PM
Author Topic: Drill Holes  (Read 15159 times)
Offline vadude
  •  18 18
  • WYSIWUG
Drill Holes
« on: November 20, 2010, 10:06:08 PM »
Can somebody walk me through how drill 4 holes with 0.25" diameter using a router bit size of 0.25" diameter using an autocad , Lazycam(unregistered) & Mach3.It was easy when i had a bit with  size of diameter 0.125"
No Pain No Gain
Re: Drill Holes
« Reply #1 on: November 21, 2010, 05:18:18 AM »
See page 41 in the Lazycam Manual. It covers drilling.
As far as CAD is concerned you can draw a circle of any size where the holes are located.
Basicaly you select the items representing the holes, define them as a drilling, and then define the motion in LC.
Re: Drill Holes
« Reply #2 on: November 21, 2010, 06:45:19 AM »
If you're using AutoCAD 2002 or newer, I have a macro that will do what  you want very easily. It's also does much. much more, and much faster than LazyCAM. Be sure to read the manual.
http://home.comcast.net/~cncwoodworker/acad/downloads/ac2gcv045.zip
Re: Drill Holes
« Reply #3 on: November 21, 2010, 09:54:31 AM »
You do the holes to be drilled as a point in Acad. Then when in Lcam do a drill cycle to the point.
Hope that helps
Offline DaOne
  •  236 236
Re: Drill Holes
« Reply #4 on: November 21, 2010, 02:41:02 PM »
If it was easy with a .125 bit it should be just as easy with a .25 bit. You go off center of the drill point. Diameter only matters for speeds and feeds. If you can provide me you machines rigitivity, HP, RPM speed range, Z axis speed and materiel I can give you some suggested speeds and feeds.
Offline vadude
  •  18 18
  • WYSIWUG
Re: Drill Holes
« Reply #5 on: November 21, 2010, 11:20:07 PM »
Hope that helps
I will try this and keep u posted
No Pain No Gain
Offline DaOne
  •  236 236
Re: Drill Holes
« Reply #6 on: November 22, 2010, 12:44:43 AM »
Let me know if you need help on the speeds and feeds.
« Last Edit: November 22, 2010, 12:46:37 AM by DaOne »
