Hello
Guest
it is
November 24, 2026, 08:12:59 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Mach Working hours
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Mach Working hours (Read 14016 times)
mrpeja
114
Mach Working hours
on:
November 16, 2010, 12:49:31 AM »
Hi guys,
I want to calculate how much my plasma table was used per month. Maybe some one has a solution?
I'll be gratefull
Mrpeja
Logged
BR549
6,965
Re: Mach Working hours
Reply #1 on:
November 16, 2010, 08:39:23 PM »
You might try the maintanance tab under operator.
Personally I use a log system. Each job that mach runs it logs the file name, date , start and finsih times. At the end of the month that file gets appended to the master log file.
Logged
stirling
2,188
UK
Reply #2 on:
November 17, 2010, 11:01:22 AM »
Quote from: BR549 on November 16, 2010, 08:39:23 PM
Does this work?
Ian
Logged
Razordance Torch Height Control
BR549
6,965
Reply #3 on:
November 18, 2010, 10:26:16 AM »
Everything but spindle on hours. I gues Brian never turned it on in the base code.
Logged
stirling
2,188
UK
Reply #4 on:
November 18, 2010, 12:01:38 PM »
Hmmmm - ok - but when I tried it, after a complete reset it gave me an A axis distance of several hundred - even though I don't have an A axis - nor was there any A movements in the code. It also gave me a session time of several hours even though I only ran a two minute job. And it also told me there were a couple hundred M3's even though there were only actually two - other than that I guess it was fine
Ian
Logged
BR549
6,965
Reply #5 on:
November 18, 2010, 12:52:00 PM »
Well it USED to work long ago I used to use it to track work(;-) AS to now?
? WHO knows?
Logged
BR549
6,965
Reply #6 on:
November 18, 2010, 01:02:59 PM »
Ian I just retested here AND it all works OK except for spindle on hours. I remember Brians saying a while back he thought he did not turn that function on in the base code.
Logged
Print
Pages:
1
Go Up
« previous
next »
