Mach Discussion => General Mach Discussion => Topic started by: mrpeja on November 16, 2010, 01:49:31 AM
Hi guys,
I want to calculate how much my plasma table was used per month. Maybe some one has a solution?
I'll be gratefull
Mrpeja
You might try the maintanance tab under operator.
Personally I use a log system. Each job that mach runs it logs the file name, date , start and finsih times. At the end of the month that file gets appended to the master log file.
Does this work?
Ian
Everything but spindle on hours. I gues Brian never turned it on in the base code.
Hmmmm - ok - but when I tried it, after a complete reset it gave me an A axis distance of several hundred - even though I don't have an A axis - nor was there any A movements in the code. It also gave me a session time of several hours even though I only ran a two minute job. And it also told me there were a couple hundred M3's even though there were only actually two - other than that I guess it was fine ;D
Ian
Well it USED to work long ago I used to use it to track work(;-) AS to now????? WHO knows?
Ian I just retested here AND it all works OK except for spindle on hours. I remember Brians saying a while back he thought he did not turn that function on in the base code.
