Hello Guest it is November 10, 2026, 03:07:41 AM
Author Topic: Slaved axis steps per unit  (Read 10265 times)
« on: November 08, 2010, 01:17:13 AM »
Im just wondering if i can tune the steps per unit 4 2 axes separately and then slave them with mach allowing me to have a different gearing from the motor to the axis on either side of my x axis but still slave them together??
Its a servo system if that makes any difference.
Matt
Re: Slaved axis steps per unit
« Reply #1 on: November 08, 2010, 02:04:37 AM »
When slaving Mach will put out identical pulses for each axis (master/slave).
« Reply #2 on: November 08, 2010, 07:35:18 AM »
Thanks hood, so that wont work then? CAn you think of any other solution apart from changing the mechanical gearing between the motor and the axis??
matt
« Reply #3 on: November 08, 2010, 07:43:52 AM »
Only way I can see is either changing the mechanical side of things or if your servo drives have electronic gearing you could possibly do it that way.
