Hello Guest it is November 19, 2026, 07:49:14 AM
Author Topic: G1 on every line causing choppiness  (Read 13637 times)
« on: November 03, 2006, 11:49:47 AM »
I am experiencing a weird situation where our machine gets choppy if there are G1 codes on every line of a 3D file.  If the codes are removed the machine is much smoother.  Any suggestions on ways to overcome this in Mach?  We use a number of CAD/CAM packages, and some have posts that are not easy to modify.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: G1 on every line causing choppiness
« Reply #1 on: November 03, 2006, 12:19:27 PM »
If you are talking about thousands of very short moves, try reducing the feed rate by 50 per cent.
You may be only cutting at the acceleration speed not the feed rate specified in the program on most of the cuts.
Graham.
« Reply #2 on: November 05, 2006, 04:31:57 PM »
That is odd... I have not seen that :( what are you running for a computer?
www.newfangledsolutions.com
www.machsupport.com
« Reply #3 on: November 05, 2006, 10:45:42 PM »
A P4.
« Reply #4 on: November 06, 2006, 05:44:55 PM »
Is this on the newest version?
www.machsupport.com
