Hello Guest it is November 10, 2026, 03:07:40 AM
Author Topic: G83 will rapid out but not in, Mach3Turn  (Read 9062 times)
« on: November 05, 2010, 02:29:34 PM »
I am using several G83 peck drilling routines in Mach3 Turn. The drilling cycle works but it will rapid all the way out and it will not rapid back in. Takes up a lot of time. I tried G83.1 and it worked exactly the same as G83.
Am I missing something?
And I am a bad boy, I am at work without the Mach3Turn revision I am running. I know this will be a question.
Re: G83 will rapid out but not in, Mach3Turn
« Reply #1 on: November 05, 2010, 02:41:03 PM »
The routines i use on the lathe in Mach Turn can be found in the Downloads >Tool Box.
Here is the link:
I know these work on the lathe from test's i did some time ago. Make sure you read how to use the macros.
http://www.machsupport.com/forum/index.php/topic,15205.msg101682.html#msg101682
