Hello Guest it is October 14, 2026, 03:05:32 AM
Author Topic: On board vs plug in LPT port  (Read 10224 times)
« on: November 04, 2010, 10:19:29 PM »
I just finished retrofitting a mchine and was going to test it when I realized there was no parrallel port on the computer I was going to use.  Oops.  I found this one:
http://www.cnaweb.com/pci-high-speed-parallel-port.aspx
It claims to work better than an MB mounted LPT port.  Anybody found any correlation between performance with Mach and MB VS high performance plug in LPT port?
I went ahead and ordered it because a Smooth Stepper is just a little more than I have left of my allowance right now.  Its EPP so it shoud work fine.
Re: On board vs plug in LPT port
« Reply #1 on: November 05, 2010, 04:08:01 AM »
Should work, how well I can't say,but, you will find out. Hopefully the drivers they supply for it will be appropriate for it and your operating system.
« Reply #2 on: November 09, 2010, 09:51:23 AM »
Works great.  I need to slow down the machine a bit, but it works fine.
