Hello
Guest
it is
October 15, 2026, 10:31:38 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
need help ! three function on one button
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: need help ! three function on one button (Read 9427 times)
kkquek
9
on:
November 02, 2010, 09:35:30 PM »
dear sir ,
how to make a button to "run,pause,continue" on one button(same button)
because my extend keypad only hace 10 button
Logged
Carnoustie, Scotland
Re: need help ! three function on one button
Reply #1 on:
November 03, 2010, 03:23:08 AM »
You are really only needing two functions, ie Start and Feedhold.
I am not sure how Mach sees buttons from such devices as extended keypads but if you can get a Brain to look at it and also look at the LEDs for Start and Feedhold then you could have your switch do what you want.
For example if the switch is active and the Start LED is active but NOT the Feedhold LED then you would have the Brain output a Feedhold.
If the switch was active but Start LED was NOT but Feedhold LED was then you would have the Brain output a Start signal.
Logged
kkquek
9
Reply #2 on:
November 03, 2010, 09:03:28 AM »
thank you
i try it
Logged
Print
Pages:
1
Go Up
« previous
next »
