Hello Guest it is October 14, 2026, 08:59:48 PM
Author Topic: mach 3 in minneapolis  (Read 9765 times)
« on: October 23, 2010, 08:11:33 AM »
i can build a machine. but need help with programing it,just don't have enough time
any one want to trade mill time or just work out payment for writing some mach 3 code
for me
Offline thosj
  •  542 542
Re: mach 3 in minneapolis
« Reply #1 on: October 23, 2010, 12:19:32 PM »
That would depend heavily on what you want programmed!! A 4 hole bolt pattern for 9/32 holes, or a 3d gizmo hewn out of a solid block with a 1/8 ball endmill!!
Might get more offers if we all knew what you wanted, at least roughly. A lot of things affect programming needs!
I don't need mill time on your mill, but working out payment could happen, again, depending on what your needs are. I'm in Wisconsin, but emailing a gcode file can span the globe!
Tom
« Reply #2 on: October 23, 2010, 02:59:41 PM »
you are right the object is about 3x4 inches about 4 drill spots
another one is about 1.6 x 3 inches with 1 cut 3 drill and 3 more
drill  same place just another drill
it has 3 curves in a space of 3 inches
and another 2 drills another surface
if i can give more information
i have a bridgeport mill
