Hello Guest it is November 18, 2026, 03:50:38 AM
Author Topic: Status error messages list.  (Read 33403 times)
« on: October 12, 2010, 02:32:02 AM »
Does anyone know where i can find a full list of the status error messages?
Giannis
Error Messages
« Reply #1 on: August 18, 2013, 12:20:14 PM »
Did anyone come up with a list of error messages ? When starting Mach mill I get "Error triggered" and cannot proceed. I have also had "Error stopping timer" Does anyone have suggestions for a fix ?
Re: Status error messages list.
« Reply #2 on: August 18, 2013, 01:11:40 PM »
THere is NO list of error messages.
« Reply #3 on: August 19, 2013, 02:39:13 AM »
Does anyone have any suggestions on how to proceed logically to investigate the cause of the error message ? Any help appreciated.
« Reply #4 on: August 19, 2013, 06:20:04 AM »
Can you run the driver test?
« Reply #5 on: August 19, 2013, 07:48:57 AM »
I have just run the driver test. It says "System under Mach3 control"
Fastest time 101483
Slowest time 101463
No reading in pulse /sec window & no graph
I seem to remember previous tests had a pulse /sec reading
« Reply #6 on: August 19, 2013, 12:18:25 PM »
Ok, can you attach your xml please, I am thinking I may know what the problem is, may not be correct but will soon know with your xml :)
« Reply #7 on: August 20, 2013, 04:08:07 AM »
Thanks for response File att.
« Reply #8 on: August 20, 2013, 09:31:55 AM »
Ok its not what I was thinking :(
What version of Mach are you running?
« Reply #9 on: August 20, 2013, 10:55:20 AM »
Its Mach 3 2.0 installed around 2007
