Hello Guest it is October 20, 2026, 08:25:21 PM
Author Topic: Possible problem with Surfacing wizard  (Read 92262 times)
« on: January 19, 2006, 05:15:42 PM »
Brian-
I has posted this a while back in the Yahoo mach forum, but the forum was really busy then and it might have slipped by you, I didn't see a response.
(originally posted on Yahoo mach forum)
Brian-
When using the Surfacing Material Wizard, the starting point for me is
always the upper left hand corner of the defined material, independent
of the selection I make for Start Position.
By the way, thanks for upgrade that automatically calculates chip load
based on the tool properties.
Paul T.
Re: Possible problem with Surfacing wizard
« Reply #1 on: January 19, 2006, 06:14:43 PM »
Yea it is going to start in the same place every time:( The points are to change where the X0 Y0 is not the start point.
Hope that helps, and I am sorry I didn't see the message
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: January 20, 2006, 12:12:08 PM »
Whoops, a senior moment on my part, that makes more sense.
Paul T.
