Hello Guest it is October 22, 2026, 07:23:17 PM
Author Topic: step feed rate in jog mode  (Read 13983 times)
« on: September 28, 2010, 09:17:36 AM »
Dear Sir
Mach3 has 'step' and 'continuous' in jog mode. Continuous jog speed can control with job slow rate setting. How can I control 'step' jog speed? The feed rate for step job is 6 mm per minute. It is very slow for me. I want to change the feed rate in step mode while jogging. How can I change? Please help me...
Best regards,
High Tech Key
Re: step feed rate in jog mode
« Reply #1 on: September 28, 2010, 09:35:27 AM »
Dear Sir
Now I can change this feed rate. It is working with default feed rate. My mach3 default feed rate is 6mm per minute. How can I change my default feed rate? I want to set my default feed rate about 500mm per min. I mean I want to have 500 mm per min when my machine is start.
High Tech Key
« Reply #2 on: September 28, 2010, 10:17:59 AM »
General Config page and put F500 in the initialisation string box.
