Hello Guest it is November 01, 2026, 10:10:20 AM
Author Topic: Missing parts from DXF import  (Read 8790 times)
« on: September 27, 2010, 01:20:48 PM »
I have created a DXF file in AutoCad, and imported it into LazyCAM successfully and all components of the drawing show up in LC.
However once I generate the G code and load it into Mach 3 only portions of the picture are present.
I cannot see a correlation between the parts that show up and those that do not. The only difference I see when importing the file are that some entities show up as a green line an others as a blue line.
I am new to LC and not sure what the different colors represent.
I have made sure the original DWG file has good connections and no unterminated lines.
Any suggestion on what is happening?
I have tried this on two different files, in both cases the DWG file was created from a scanned image using Raster to vector conversion, then cleaned up in Autocad and saved as a DXF file. I have made certain all lines inthe DWG file were on the same layer, and same line type.
Kevin
Re: Missing parts from DXF import
« Reply #1 on: September 27, 2010, 03:48:42 PM »
I believe I have resolved my issue.....turned out I had not installed the Mach 3 license file....once that was in place the entire picture showed up
HOWEVER.....when I went to cut the item, it looked good on the Mach 3 screen, but when I cut it out....it reversed the image (a mirror image) of it.....has anyone ever heard of this??
Kevin
« Reply #2 on: September 27, 2010, 08:49:39 PM »
Yep. One axis of your machine is set up backwards.
