Hello Guest it is November 18, 2026, 11:47:37 PM
Author Topic: TAIG 3000 DSLS  (Read 36152 times)
Re: TAIG 3000 DSLS
« Reply #10 on: September 26, 2010, 03:35:07 PM »
i try this but when i off the z limit switch the z axis dont move corectly move cuple steps and stop after this i see in monitor the z ups but not move in the mill
Re: TAIG 3000 DSLS
« Reply #11 on: September 26, 2010, 03:37:09 PM »
Is the motor making a loud noise when you are trying to move the Z?
Re: TAIG 3000 DSLS
« Reply #12 on: September 26, 2010, 03:38:48 PM »
no like other motors when it going down its just fly normaly but up its nitgmare
Re: TAIG 3000 DSLS
« Reply #13 on: September 26, 2010, 03:45:06 PM »
Try this
First move the Z axis down then zero the Z DRO and then go to MDI page and enter G1Z1F1 and press the enter key on the keyboard and see what happens.
Re: TAIG 3000 DSLS
« Reply #14 on: September 26, 2010, 03:49:35 PM »
the z move like clock tik tak and go 1 up
Re: TAIG 3000 DSLS
« Reply #15 on: September 26, 2010, 03:52:35 PM »
So it went up but stuttered? Sounds like your motor may be struggling to lift the Z against gravity. Can up unhook the motor and see if it moves ok in both directions when you jog.
Also check the axis moves freely by hand and there are no tight spots.
Re: TAIG 3000 DSLS
« Reply #16 on: September 26, 2010, 03:54:59 PM »
i go to check
Re: TAIG 3000 DSLS
« Reply #17 on: September 26, 2010, 04:33:48 PM »
ok first of all  greeeeeeeeeeeeeeeeeeeeeeeaaaaaaaaaaaaaaaaaaaaaaaaat thanks for this moment everything works correct hopes its stay like this and sometime big problem for somebody its simple solution to enother thank you my frend and if it no big problem ijust want to know you name to know you personal and again great thanks to you
Re: TAIG 3000 DSLS
« Reply #18 on: September 26, 2010, 04:54:31 PM »
So what was the problem? A binding axis?
Re: TAIG 3000 DSLS
« Reply #19 on: September 26, 2010, 05:02:10 PM »
i look the bolts to strong
