Hello Guest it is November 22, 2026, 08:01:36 AM
Author Topic: Reversing Axis  (Read 11933 times)
Reversing Axis
« on: September 23, 2010, 09:00:13 PM »
All,
My frustration is at an all time high. >:(
The latest problem centers around my z-axis reversing direction after each push of the jogging key. All was well
a week ago and I was making the final connections of my limit switches and things went south. I had run the break-in program 3-4 times
prior to this setback. I rechecked my connections and all appears to be fine. Has anyone experienced this and if so, what or where can I look to solve this issue.
Adrian
Re: Reversing Axis
« Reply #1 on: September 24, 2010, 01:15:41 AM »
You can reverse the axis by going to Config menu then Homing and Limits.
If you still have problems please attach your xml.
Re: Reversing Axis
« Reply #2 on: September 24, 2010, 08:18:27 AM »
Hood,
Thanks for the suggestion. The axis reverses randomly each time you press the +Z or -Z button. I will post the xml this evening.
Adrian
Re: Reversing Axis
« Reply #3 on: September 24, 2010, 08:20:56 AM »
Sounds like you have a bad connection on the Z Dir wire or you are getting noise picked up by it.
Re: Reversing Axis
« Reply #4 on: September 24, 2010, 08:53:56 AM »
I did run my power for the router in the same power track. I will unplug the cord and see if it makes a difference.
Good suggestion!
Adrian
Re: Reversing Axis
« Reply #5 on: September 24, 2010, 12:43:25 PM »
Good chance that is your problem.
