Hello Guest it is October 21, 2026, 07:58:58 AM
Author Topic: reverse axis  (Read 10929 times)
reverse axis
« on: September 21, 2010, 07:52:50 AM »
hi all,
is there a setup in mach to make my x axis go in the opposite direction after installing a new board the y and z are ok but the x is going the opposite way to what it used to,i have checked the wiring to make sure its the same as the others and it is ok its probably just a daft switch somewhere in mach but i just cant find it, or do i have to turn the motor around?
thank you.
john :-[
Re: reverse axis
« Reply #1 on: September 21, 2010, 07:59:02 AM »
Config menu then Homing and Limits and then change  the reverse setting for the axis you wish to reverse.
Re: reverse axis
« Reply #2 on: September 21, 2010, 08:30:11 AM »
thank you thank you thank you your a star you have now idea how long i looked at this and just couldn't see it,all the best my friend  ;)
Re: reverse axis
« Reply #3 on: September 21, 2010, 08:36:06 AM »
Ha ha no probs :0
