Hello
Guest
it is
October 20, 2026, 09:01:26 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
adding an optical switch to the spindle
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: adding an optical switch to the spindle (Read 10140 times)
capsteve
36
on:
September 18, 2010, 02:49:43 PM »
Is there a favorite part# that most use for optical switches? I would like to find one that would
Have electronics onboard to allow me to hook up directly to mach. I don't know enough about them
To make an intelligant decision.
Carnoustie, Scotland
Re: adding an optical switch to the spindle
Reply #1 on:
September 18, 2010, 03:06:36 PM »
Optek OPB917B is what I used, only need to add a resistor on the LED positive wire to limit current. 220 Ohm for the 5v supply is what I use.
capsteve
36
Reply #2 on:
September 18, 2010, 11:08:09 PM »
thanks,
i'm not sure but does it look like it should be able to switch 24v on the output side?
steve
Sam
987
Reply #3 on:
September 18, 2010, 11:35:58 PM »
This may be of help.
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=365-1264-ND
Print
Pages:
1
Go Up
« previous
next »
