Mach Discussion => General Mach Discussion => Topic started by: capsteve on September 18, 2010, 03:49:43 PM
Is there a favorite part# that most use for optical switches? I would like to find one that would
Have electronics onboard to allow me to hook up directly to mach. I don't know enough about them
To make an intelligant decision.
Optek OPB917B is what I used, only need to add a resistor on the LED positive wire to limit current. 220 Ohm for the 5v supply is what I use.
thanks,
i'm not sure but does it look like it should be able to switch 24v on the output side?
steve
This may be of help.
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=365-1264-ND
