Hello Guest it is October 21, 2026, 09:14:41 AM
Author Topic: problem xyza drive fast ?  (Read 21732 times)
Re: problem xyza drive fast ?
« Reply #10 on: September 19, 2010, 04:40:16 AM »
yes stirling  you are right the steppers are direct to ( helical couplers)    and  its  tb6560 driver . thanks
« Reply #11 on: September 19, 2010, 05:14:01 AM »
Thanks Ian.
Ok if your drives are set to 1/16  your steps per will be 320
If set to 1/4 then 80
If set to 1/2 then 40
Try the 1/16 setting first, ie put 320 in for steps per unit.
« Reply #12 on: September 19, 2010, 05:28:25 AM »
thank you its ok  know its working fine.
