Hello
Guest
it is
October 21, 2026, 12:16:21 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
problem xyza drive fast ?
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: problem xyza drive fast ? (Read 21734 times)
kocher
21
Re: problem xyza drive fast ?
Reply #10 on:
September 19, 2010, 04:40:16 AM »
yes stirling you are right the steppers are direct to ( helical couplers) and its tb6560 driver . thanks
Carnoustie, Scotland
Reply #11 on:
September 19, 2010, 05:14:01 AM »
Thanks Ian.
Ok if your drives are set to 1/16 your steps per will be 320
If set to 1/4 then 80
If set to 1/2 then 40
Try the 1/16 setting first, ie put 320 in for steps per unit.
kocher
21
Reply #12 on:
September 19, 2010, 05:28:25 AM »
thank you its ok know its working fine.
Print
Pages:
1
2
Go Up
« previous
next »
