Hello Guest it is November 20, 2026, 07:13:00 AM
Author Topic: G CODE TO CUT PARAMETRIC CURVES.  (Read 16088 times)
« on: September 15, 2010, 08:46:47 AM »
Greetings.
I am looking for information about writing GCode to cut mathematical curves in wood.
For example, code to cut a sin curve.
If I can see an example, I am sure I can take it from there.
Help appreciated.
Re: G CODE TO CUT PARAMETRIC CURVES.
« Reply #1 on: September 15, 2010, 07:32:30 PM »
make a mcode and call it up in a program
m1212.m1s
For varX = 1 To 10
    varY = Sin (varX)
    Code "g0 X"& varX & "Y"& varY
Next varX
« Reply #2 on: September 17, 2010, 08:45:26 AM »
I thank you bud.
Obviously, it is not the stroll in the park I imagined it would be.
Do you have any references to custom mcode coding please. I want to do some reading.
« Reply #3 on: September 17, 2010, 03:45:59 PM »
There is also a parametric side of Gcode that you may want to look at. It has most of the math processes you may need such as sin cosin,etc
Just a thought, (;-) TP
« Reply #4 on: September 20, 2010, 12:51:35 AM »
Hi.
I am very intersted in that too.
Can you point me in the direction of texts/sample parametric gcode please?
I just want to control my shapes very directly in mach3.
« Reply #5 on: September 20, 2010, 10:34:43 AM »
Look in the Mach Manual under Gcode parameters/variables.
« Reply #6 on: September 20, 2010, 10:36:13 AM »
Thanks bud.
Will do and revert.
« Reply #7 on: September 21, 2010, 05:10:53 AM »
Wow: All of chapter 10.
Guys, I thank you very much indeed.
Deep regards.
